D100: Coaxial vs Toslink?
 Posted: Wed Nov 04, 2009 7:26 am
Posted: Wed Nov 04, 2009 7:26 amHello Wes, I was wondering if you might please share your thoughts on whether you recommend using the optical vs coaxial connection with the D100.  For example: I believe the D100 coaxial input is transformer-isolated (correct?) - does this mean that ground isolation should be identical for its coax and optical inputs?  Also, I've heard that optical is inherently more jitter-prone - is that your understanding as well, and have you found this (or jitter in general) to even be relevant to the D100?  Any further info here from you on this topic would also be appreciated - thanks!
P.S. I'm really glad you are still offering the first edition of the D100, as 1V output is PLENTY for our system.
